Hi
I've just pulled down an old lath and plaster ceiling as part of a rewire (was below a kitchen in the flat above with a tiled floor, and as it has suffered a leak or two from above in the past I thought it an ideal time to replace).
I'm thinking about insulation and measures I can put in place to try and soften any damage caused should the flat upstairs leave their taps on again. I've got some of the recycled plastics insulation to put between the joists and was thinking about adding a polythene sheet, stapled to the joists to hold up the insulation prior to plasterboarding, and to catch any minor leaks from above. Is this a good idea? Thoughts would be really appreciated! Oh, and wiring will be secured to the joists, and will just make a small hole in the polythene to bring the cable through for the light.
Many thanks!
Many thanks!
