Hello,
Little problem with trying to wire a ceiling light. The wiring first of all is very bizarre with 3 reds twisted together, 2 blacks twisted together, 1 stand alone black and another yellow/brown wire.
Ive put the 3 reds into the live terminal and the 2 blacks into the neutral terminal and the light comes on just fine, but the switch wont work! The live switch wire I am guessing is the stand alone black one. The light im fitting itself is weird in that it ONLY has 2 terminals - live and neutral. So I am stuck as to where I should put the switch wire - ive tried putting it in along with the reds but switch does not work and tried it with the neutrals and the trip switch went - any suggestions would be much much appreciated!
