ok - I know I'v done a daft thing and I'm therefore willing to take any negative comments along with the more positive (bit of a pun going on there - sorry)
I have been through all the FAQ's and any posts I could find relating to Ceiling lights and I haven't found anything like what I have on my lounge ceiling .
To try to simplify your task, I have taken a photo of the rose as it is wired.
Basically on the ceiling rose wiring, there is the following:
4 black wires going into a metal connector with three holes, two wires are screwed into each of two holes, a third hole has no wires in it.
3 red wires going into a second metal connector, one single wire in each of the three holes.
4 earth wires which are connected together in a third single metal connection.
1 yellow and green wire going into a single metal connection.
Then 2 red wires and 1 blue wire going into the plastic connector.
The light I want to wire up has the usual cable with brown, blue and yellow/green wires, plus a thicker earth wire from the brass light fitting.
In the room I have this central light I need to wire up, plus two wall lights which are wired.
They are controlled by two independant dimmer switches, one for the central ceiling light and one for the two wall lights.
Where do I put what wire? (No rude comments please, I know I should not be doing this myself but at present have no other option)
[/img]
