ceiling light powered from 3-pin plug?
7 Mar 2021
Hey all,
Sorry if this is a stupid question, but I'm mainly looking for reassurance that I'm not doing something dangerous...
I have a conservatory without a hard-wired light fixture and I'd like to add a fitting but power it from a wall socket.
From googling, I can't find any reason why it would be unsafe to wire a standard ceiling light fitting (i.e. something designed to wire directly into the lighting circuit) directly to a 3-core, 0.75mm² cable with standard 3-pin plug to power the light directly from a wall socket. I'll only be using 1 LED bulb so I think a 3A fuse should be fine? Is that all correct?
To reach the ceiling, the cable will be quite long (~7 meters) and I'd like to add an in-line rocker switch. Would either of those pose a problem or add any extra safety considerations?
Thanks both. That's what I thought, but I have zero experience.
As a side note, do you know any good places to learn the basics you need for doing small electrical jobs around the house safely?
I’m not an electrician so can’t really give advice, but YouTube has a video for almost everything.
