I've bought a new pendant light - the instructions say to wire live in the light fitting to live in the ceiling, neutral to neutral (using a jointing block).
But...all the wires coming out of the fitting are white (a whitish tranlucent casing round the cables). One of the 3 wires is slightly longer than the other 2 but other than that there is nothing on any of the 3 wires to differentiate them.
There is also an earth wire, but this attached inside celing rose part of the fitting - it' not connected, or even close to, the other wires. So assuming this is the earth, what are the 3 wires in the fitting?
I've changed 'normal' light fittings before but never come across 3 wires the same colour. Is there a way of telling which is live and which is neutral? If all else fails and I go for a trail and error approach, I assume the fuse and/or bulb would blow - is the worst that would happen
