Ceiling mounted extractor fan
M
marsaday
I cannot exit the room via the wall for my fan, so it is going to be the ceiling and then up through the roof.
Any recommendations for the size / type of fan. It will feed into soil pipe which will go through the roof. The distance travelled will be approx 2.5m. I will lag this pipe to help prevent condensation.
Does it need to be low voltage as it will be above the shower head area.
Ps, BC are involved and i will have a sparky, but just wanted to get some recommendations on good fans.
3 Nov 2006
Bedfordshire
Arrange for a condensation trap to divert water running down the inside of the pipe away from the fan and into a suitable drain. ( dripping from the end of a 20mm pipe through the soffit board for example )
I assuming you are not using the existing soil stack pipe for the vent.
27 Aug 2003
London
I'd insulate the drain pipe too, and try to get the run as steep as possible - you don't want it freezing up, because then the condensate won't drain away...
