Guys, you have probably answered this question a 1000 times but i'm not 100% sure. Here's my situation.
Ceiling Rose 3 terminal blocks
Terminal 1
Light (L)
Switch Return
Terminal 2
Switch feed
2 x mains Loop (L)
Terminal 3
2 x Mains Loop (N)
Light (N)
Spotlights 4 terminals
Supply Lighting
loop unswitched live to loop unswitched live
above is on a separate block
Black (N) to Blue(N)
Earth to Earth
Switched Live to Brown (L)
Here's my question
is the switched live wire on the spotlight the same wire as the switch return on the rose (terminal 1). If this is the case do I then put the all the other red wires into the separate loop unswitched live terminal on the spotlights
Thanks Guys
Terminal 1
Light (L)
Switch Return
Terminal 2
Switch feed
2 x mains Loop (L)
Terminal 3
2 x Mains Loop (N)
Light (N)
Supply Lighting
Earth to Earth
Here's my question
Thanks Guys
