celing downlighter fittings safety advice
14 Apr 2007
I have been asked to fit some flush celing downlights in a bathroom, apparentley thay are ip65 rated, which makes them suitable for the bathroom enviroment, is this correct?
Also the loftspace above the celing is freshly insulated with thick insulation. What do you proffesional chaps fit these fire proof hoods that cover the rear of the unit, and if so is it ok to place the insulation back over these hoods.
They either are or are not, apparently being rated so is not really cutting the mustard!
If they are? Then yes! If they are compliant to part C of building regs?
Some are designed to have insulation recovered, you may find some are not! So get the right product there are plenty of them about. I personally prefer the galvanised insulation guards. And you should fit them not only for protection but also to prevent compromising the insulation properties of the room/property!
They organised that the wrong way round. Fit lights first then insulation.
Fire hoods are NOT required unless the bathroom ceiling is a fire barrier (it wont be).
Use a loft cap
or a loft brace
