- Joined
- 2 Feb 2007
- Messages
- 105
- Reaction score
- 0
- Country
Hi
Today I have been helping my uncle strip his front room to have his plaster re skimmed, we took down the ceiling roses making note of the wires to go back later. After working on and having seen both loop-in systems and junction box systems I'm not entirely sure what he has.
It's no major problem because the roses/light will go back as it was but I'm curious to what it is. The house is about 1965 with no earth on the lighting (one circuit). In the rose it has two twin cables, containing black and red in each as you would expect, 1mmsq. All is original and not identified in any way ie red/black Switched Live tag.
We have;
Two reds are joined in one terminal (Live, these end here)
One of the blacks goes to one terminal (which in turn is blue flex/Neutral to bulb)
The other black to the remaining terminal (which in turn is the brown flex/L to bulb)
I need confirmation that one of the two cables is likely from a junction box on the lighting circuit, obviously one of the joined lives runs to the switch and returns as a switched live (brown on flex). In effect a continuous in-line switch and bulb?
I hope that makes sense - hard to explain in typed words!
Thanks!
Kevin.
We have;
Thanks!
Kevin.
