- Joined
- 26 Jan 2017
- Messages
- 1,027
- Reaction score
- 65
- Country
Is the expected lifespan of a British tank the same as a US tank as in the link above?
There's going to be a lot of oil tanks ripped out then..Or are you just inventing clauses?Accurate information here
https://www.gov.uk/oil-storage-regulations-and-safety/home
https://www.gov.uk/guidance/storing-oil-at-a-home-or-business#exempt-oil-storage-containers
If being compliant with latest standards / regulations is written into the insurance document then they will be able to get away with it..
We have seen indoor oil tanks easily in good condition that are 60 years old or older, and we have found failures in newer oil storage tanks that may have been made of thinner or cheaper steel and that did not last as long as the original ones. -
Don't forget who helps to drive the regs the insurance companies and they're always looking not to pay out if your tank instalation does not comply and anything happens they will send an adjuster who is OFTEC wise and I can tell you now you will not get paid a tank shouldnt be in a building unless it's constructed to have a tank in it it has to be fire resiting and should not be able to be locked from the outside so a garage is out cos you lock a garage and should you not someone will steal you car or valuables left in there so get a new tank outside and get rid of the problem.Bob
