I just had another line of thought, one never knows what happens when one who does not fully well understand the function of things in general, can end up using them
I can safely assume someone has connected the 3 port valve incorrectly, now that you have determined your flow is fine as you have managed to get all your rads red hot! Time to trace exactly the hot water flow pipe from the boiler to this diverter valve and make sure it is plumbed into the in coming port, usually in the middle, as the middle part
Obviously I cannot rule out yet another unlikely possibility, a 3 way valve internals could be assembled wrongly whereby it will open in two settings and fail to open in a 3rd
p="2316940"]
The op needs some help in identifing the cause & ways of prooving or discounting suggestions/theories in order to identify and resolve the issue. Perhaps after reading the thread you could provide some tests/solutions to help?
i will buy a couple of these temp gauges tommorrow presumably from a plumbers merchant and will run the test for temp and check which pipes get hot 1st that connect to the HW tank.
Mike has made some good points, which goes with some questions I have.
Originally the boiler was gravity primaries, what happened to the htg connect at the boiler ??
To add to Mikes post, supposing he was closer than he thinks, and the pump and MV are actually on the return sucking out of the boiler.
Bills drawing actually shows something like that but it may have been indicative and not intentional.
Supposing the htg return was then connected to the bottom pipe and the flow from the MV, then the flow and return would be common either side of the pump/MV, and could in affect bypass the boiler.
