I must agree i read this forum a lot and Tony a lot of your comments are very condescending towards people. Im a fairly inexperienced engineer (around 5yrs on the tools) and you are the kind of person on a daily basis I hate coming across a Mr Know It All. No doubting your probably a fantastic engineer but not everybody is intent on boasting about it the way you are. People are looking for pleasant advice on this forum not u and ur smarmy comments.
what i failed to mention is that after my mistake a brand new pump was fitted, so your theory does not hold water, pardon the pun.
okay situation so far is that all rads are getting warm but not to temperature, think there may still be a blockage somewhere and it may be a case of cutting some pies at some stage possibly.
i placed a call to the company who did the flush and they are coming back in the next couple of days to strip the boiler and check the heater exchange i think they said, they also mention that the boiler may never get to temperature as they believed it was too small for the premises think they said the output was 1800btu they didn't mention what size they think i should have if this is the case, but i will ask when they return.
What i have done is to try to switch all rads off except 3 to see if they increase in temperature on the advice of the plumber who installed the new pump last week.
I thought you said you did the flush as it was too expensive to get a professional in?
What size are the pipes to the radiator, a radiator should be the very last resort to do a powerflush from.
Did you ballance the system correctly after the power flush?
Did you set any manual by-pass that may be fitted back to it's original setting?
Is the pump on the right way and settting correct?
If none of the radiators at all are getting hot, then the partial blockage is between the boiler and the first tee to the first radiator.
All in All you need to get someone out who's know's what there doing.
i initially did the job myself then as posted i got a firm in to rectify my mistakes.
the pipes are standard 15mm to the rads, and the pump was fitted by a registered plumber, their are no manual bypass valves etc.
as per prior post i have switched off 8 rads, the 3 remaing are piping hot, if waht i am told is correct then i should hopefully be a able to localise the problem by this method before the company who did the flush returns, if not they will hopefully find the problem upon their return.
Any one have any sugestions while i wait for the revisit what else i can try in a bid to fault find, bearing in mind i have little knowledge.
Have the cold feed and expansion pipes been cut out to check for blockages there?? Use a magnet where they T into the flow pipe??
A powerflush machine will never shift a proper blockage no matter what chemical is used..the blockage needs to be cut out and pipework cleaned or replaced.... and 75% of the time if all the rads are affected then its the cold feed area thats restricted.
I have never seen a potty profile heat exchanger block up so would be doubtful on that one!
Pipes have not been cut out as yet, but i will suggest this to the plumbers when they come if they don't suggest it first, as far as i am aware they are doing a full service on the boiler and cleaning the matrix they advised.
