Hi all
A few days ago, my central heating would not come on but the hot water was working fine. I have a 3 port diverter valve on which there is a lever which I turned to the right but with no luck. The lever just seems to push to the right wihout any sort of resistance.
I opened the cover on the diverter valve where I came accross a set of teeth on a spindle. I therefore turned the central heating to on and then I gave the teeth on the spindle a little push and hey presto, the heating came on.
However, I have noticed that the hot water gets hot when the central heating is on for a few hours. It gets hot as if the hot water was put on. Because of this, I have not bothered to switch the hot water on! This is not normal and I was wondering what the problem might be. Also, is this dangerous and would the hot water stat kick in when the water reaches its set temperature?
Any help would be appreciated.
Thanks.
Thanks.
