central heating pump Urgent Help!!!!
2 Jun 2005
Bedfordshire
Hi, can anyone advise me on the correct direction of flow? I removed the pump to clean it, but didn't note the direction. Should the flow be towards the motorised valve or away?
I had a trainee who forgot to check a pump direction ( once! ).
In that case it was remote from the boiler and the motor valves.
He had to try it and see the flow at the boiler. His first guess was wrong! Now he takes my advice and checks first and draws an arrow on the adjoining pipe!
Tony
If you can trace the pipe back to the boiler, the pump should be on the flow, ie the pipe conected to the top of the boiler, and the arrows on the pump should point away from it.
Whilst that is the correct way to design most systems nowadays, older systems used to have the pump on the return because it ran cooler there. You cannot guess!
Many commercial systems have the pump on the return too.
Most combi boilers also have the pump on the return. ( I would say all but someone will know about one that I had forgotten about with it on the flow! ).
Tony Glazier
jeeeeeeeeeeezzzzzzzzzzzzzzz
im a complete moron.........and even i can say pump toooooo motorised valve. as per oilski.
think abaaaaaart it.
Nothing to think about really
Well here's something. What if the pump was on the return and the motorised valve is one of a pair of 2 ports? The pump would then be pumping away from the motorised valve. Unlikely, but not impossible.
Get a life.
Get a life.
No need for that, Gasman1015. Chris is absolutely right. It's unlikely but possible.
Carctol - all you need to remember is that the pump should drive the water from the highest point in the boiler to the lowest point, regardless of where it, or the valve, sits in the circuit.
Thanks for that Paul, but I took the view that Gasman was just making himself look silly with that comment, so I ignored it.
Indeed he was. This is a subject close to my heart. Once, laid up wth flu, I had to call an engineer (CORGI) to replace a pump that broke down in mid-winter. He fitted it the wrong way round and rogered the boiler. "Oh, I thought it was one of those with the pump on the return" said he, writing out a bill for £180.
From that point on, I vowed to do all this stuff myself.
hold on....the idea is to pump water to valve surely??
you f£kking dipsticks.........
and just to make sure....
yoiu f£kking dipsticks.
