- Joined
- 8 Mar 2010
- Messages
- 354
- Reaction score
- 8
- Country
classic plumber line trying to condemn a bulletproof kingfisher boiler mate, don't let them mug you off for a full swap if the cast iron heat exchanger is fine. for those 30 year old 1 1/2 inch pump nuts, soak them in plusgas for an hour then get a blowtorch on the iron nut while holding the pipe with a decent footprint wrench so you don't twist the copper. if they're completely fused, the proper trick is just buying a grundfos ups3 or similar pump head, unbolting the 4 allen bolts on the pump face, and leaving the existing iron pump body in the pipework so you don't even have to crack the unions.
Last Friday, in a kinda 'panic' mode, had a local plumber come around and virtually condemned the boiler. One of his solutions was to remove one rad and replace with a smaller one as a temp fix and join the pipe to the rad with a pump.
Also told me all about having to drill holes in the ceiling which may be Artex, etc. and would have to get an asbestos report before they could do anything. And as access to the boiler was so restricted, it would have to be pulled from the cupboard to replace the pump. The bad news just continued to get worse. Received his quote today for a complete boiler replacement, £8.5k
But having removed all the panels and vacuumed X years of dust bunnies, I can see that access to the pump nuts is not a big deal and certainly will not involve removing the boiler. So he has quoted himself out of a job.
Many thanks for all the advice and I will get a completion photo when the job is done.
I do know that the Corgi pump is not the highest quality but my good friend, Mr A. Intelligence tells me that I can expect up to 10 years of light, domestic use. By that time, I will be in my 80ies and most likely planning to sell the place. So I'll take my chances!!!
