Central Heating pump
Thanks for the link. Am going around this morning to get rid of X years of accumulated dust so that I have a better view of what is what.
I see that a head unit is available, so perhaps it will not be necessary to remove the two 1 1/2" nuts. Your link also shows the isolation valve in more detail which is useful. Pretty much what I can already see.
classic plumber line trying to condemn a bulletproof kingfisher boiler mate, don't let them mug you off for a full swap if the cast iron heat exchanger is fine. for those 30 year old 1 1/2 inch pump nuts, soak them in plusgas for an hour then get a blowtorch on the iron nut while holding the pipe with a decent footprint wrench so you don't twist the copper. if they're completely fused, the proper trick is just buying a grundfos ups3 or similar pump head, unbolting the 4 allen bolts on the pump face, and leaving the existing iron pump body in the pipework so you don't even have to crack the unions.
This forum really shines when you get replies from folk who are still on the tools. Thank you.
Removed the side panel this afternoon and access to the pump connections is not a big deal. I would try the central screw thing but the pump is kinda beside/behind the boiler/ wall and access from the top is restricted by the flue and some piping, so cannot actually 'see' the screw unless using a mirror. Removing it would be a touchy-feely task with no direct view and a risk of dropping the screw cap.
The current pump is a Grunfos 15-50 x 18 which is listed a discontinued but does have an anticlockwise rotation arrow.
Checking the internet, replacement Grunfos are not the cheapest but perhaps that is the way to go. Other brands are around half price; Strada (https://www.mpmoran.co.uk/strada-pr...tic-heating-circulating-pump-230v-109142218); Parker (https://www.parkerbrand.co.uk/circulator-pump-pcp-156-130/) etc. Are alternatives all much of a muchness?
Most that come up from an internet search have a clock wise rotation; presumably I need anti-clock, as the current, non-working one?
Wilo used to make a pump that was a straight swap for your pump and a lot cheaper.
Thanks for all the suggestions. I'm pretty good with DIY but like to have my ducks in a row before starting something like this. It's not exactly challenging, but with 30 y/o fittings, who know what can happen.
Perhaps another silly question, have found a replacement pump on ebay, complete with new gate valves. It would be nice to replace the valves, but that will mean draining the system. Given that the valves have not been used for at least 15 years, and I have given them a 2 rev turn so know they are lose, is it worth replacing them?
If it ain't broke, don't fix it???
Doing so creates the new issue of 15 y/0 olives, removing them, etc when at the moment, there are no leaks. My personal feeling is to leave them, but what do I know?
Apologies, I didn't see if this was answered. Did you check there's power going to the pump when the heating's called for? On the valves, with the system already drained for the pump, I'd replace them. Old gate valves are a common source of leaks later, and it's the cheapest time to do it.
Thanks. Have not checked if there is power (pretty stupid, right?) but given the cable is only from the controller to the pump, there is hardly any reason for there to be a failure. But I will check.
Agreed about the gate valves, easier to replace now. But I'm hoping not to have to drain the system.
One video implies that by sealing both pipes in the loft expansion tank, the only water that can escape is from the vertical pipe from the loft. Is that correct?
Those valves may be holding, open and shut each one 4 or 5 times, then shut them and open the bleed valve on the pump front (it should have one) to check if they are holding. You can buy two isol valve "nuts", these have notches cut in them, use a junior hacksaw to cut across the existing nuts which will split quite easily then to remove, you can slip the new ones over the flanges and you are back in action.
You said The current pump is a Grunfos 15-50 x 18, 18 probably means 180mm between the flanges so measure this and ensure that the new pump is likewise.
What pump have you sourced as a replacement?.
