Current regulations for new installs and boiler changes state you must have TRV's on all rads except the room in which the room stat is fitted, usually the hall or the lounge.
Go for a Honeywell wireless analogue room stat, just a basic stat and change your main programmer. Job done.
I have shed loads of electrical experience, but very little with CH components & systems.
Which Honeywell model numbers do you recommend?
Don't you rate the programmable stats?
Is there a Honeywell programmer that has a timed boost?
I like the idea of TTC's programmer, but if I could find a Honeywell programmer with timed boost & a Honeywell stat to match, the wiring hopefully will be even easier.
