hi guys. complete amateur here!!!
my problem is this!
I have bought my first house (hoorah) but have some central heating and hot water probs.
First is that there are no cylinder stat or room stat which in the winter was chuffing expensive!!! there was an old prgrammer which i have replaced.
system is as follows.
Glowworm fuelsaver 2 boiler
horstmann c27 programmer
Honeywell valve 4043 22mm
Grundfos super selectric pump
Myson aerjec 22 de airator
i really dont even know what sort of system it is as reading on the web and what i have dont seem to add up.
The aerator thing seems to be sending water away from the pump according to the diagram on the front
The pump sends water through to the cylinder and also to the valve after the cylinder junction which appears to control the heating.
To valve is wired so that the brown wire is activated by ‘CH on’ on the programmer. The blue is wired into -. Earth is also wired in. the rest are not wired in on the valve, which points at a W plan, except it’s a 2 way motorized valve not a 3 way!!
The pump comes on when the hot water is called for. Which also confuses me as I thought it was a gravity HW system.
Everything I read on the web makes me think that this system is a bit messed up and leaves me stumped about wiring my thermostats in correctly.
What sort of system do you all reckon it is???
what would the best way be to put the stas in?
Jon
my problem is this!
Jon
