- Joined
- 11 Mar 2021
- Messages
- 6
- Reaction score
- 0
- Country
Hi Guys - I hope you can help as I'm in bit of a quandary!
I live in a well insulated bungalow in Norfolk. We have solar PV 3.92kW array, Solar Thermal, a Clearview 650 12kW wood burner with back boiler and a Gledhill Multifuel Solar Thermal store 525lt which has 3kW immersion heater - we have 5 rads and a bathroom towel rail with all heat coming from thermal store. All installed in 2012 prior to our ownership. I have fitted electric underfloor heating in our hallway as a core warmth. We do not have Economy 7 (or whatever it is called now). My electric bill last year was £853 and through Fit's and RHi I got back £1054. We have an EPC of B+
Here's my problem.
Whilst we never have any issues with hot water for 2 showers etc provided in summer and good days like last weekend by the solar panels, and during winter months by the wood burner (only normally used for around 3 hours in the evening) I have an issue with the heating system. Currently if, on a really cold day I want to run the rads (I work from home in architecture lol) from the moment I turn the hall stat up the rads are hot within a few minutes but this only lasts for around 10 mins before cooling off as obviously all the stored hot water is being used up! This isn't sufficient to heat any rooms to any degree but also means I then need to use immersion heater in 1 hour boost to get hot water up to temp again for showers etc. To compensate we tend to trundle a couple of Delonghi electric oil rads around yet still manage low bills.
My question is I've been looking at loads of options such as new ASHP (even with gov grant this will still be £9k and told involves a lot of disruption with removal of all old rads etc and so on. We do not have gas apart from LPG for cooking hob and I don't want oil as nowhere for boiler inside, no where to hide a tank and I don't like the ever present smell of heating oil!
I've been told to firstly to fit an inverter to use the electric from the PV panels that is wasted?also replace my existing TS with a modern more efficient model (I've no idea which). The next thing is to install an electric boiler to run purely the heating somehow linked through TS to ensure should tank ever get too hot from the powerful wood burner excess can be run off by turning rads on (there are 2 heat sink rads off back boiler already). The idea is that the solar PV could run the electric boiler when needed and other appliances when not. A boiler we've looked at is one by Thermosphere - 6kW 27amp or 9kW 40amp.
Does this seem to make sense or can anyone suggest a better method as I had set a budget of around £5k. My other thought is that if we ever came to sell we don't actually currently have a real form of central heating - yes underfloor would be fab but I've fitted new laminate floors throughout and skirtings!
Would really appreciate some help so I don't make the wrong decision...............sorry for long message
Here's my problem.
