I need to replace my Grundfos UPS with the new UPS2 type and intended to simply swop the pump rotor head.
However, after shutting the gate valves (top and bottom) and removing the bleed screw the flow of dripping water never ever ceased. Upon prising the rotor from the housing, too much water seeped out and I gave up.
These valves were only fitted about 15 months ago when the original ball type isolators were found to be stuck solid.
Looks like I will have to drain some water down (a bucket full) to get the pump out in its entirety now. Any other ideas? Thanks
