- Joined
- 23 Jun 2008
- Messages
- 3
- Reaction score
- 0
- Country
The boiler hasn't worked all day and the flame doesn't seem to be lighting when I turn on a hot water tap or try the central heating.
The water pressure was below 1 first thing this morning but I've since raised it to 1 (didn't fix the issue) and then 2. The pressure doesn't seem to have dropped again but the boiler still isn't working.
I've tried turning it on/off.
The red reset button isn't lit either - it occasionally lights up, but a single press usually resolves the problem. This seems to be a different issue as I've never noticed the pressure to drop so low.
Three green lights are flashing (visible in attached photo).
The pipe outside seems dry, no leaking.
I don't have a manual so not sure of the model and I can't see a visible name/code on the boiler.
Thanks in advance for any help[/b]
