CHANGE SATCHWELL TLX 2203 FOR A DRAYTON RTS8
29 Nov 2014
London
Can anyone tell ne the connections to replace my old room stat (SATCHWELL TLX 2203)with a ( DRAYTON RTS8)stat please
A straight swap is:
Satchwell terminals....3....4....1
Drayton terminals......L....N....3
However, like that, there is a load limit of 2A which should be enough.
If you need more, up to 6A, then remove the Neutral.
Perhaps a picture of the Satchwell with the cover off before you disconnect will help.
I believe the 2203 is equivalent to 2259
On 2259 the connections are : L to 3 N to 4 o/p to 1
On the RTS8 the connections are : L to L N to N and o/p to 3
Darn it pipped to the post !
