It often surprises me that people will disparage references to, for example, "32 amp cable" since the cable's current carrying capacity depends on the installation method, but are quite happy to talk about a "32 amp switch" as if it has a rating that does not depend on the duty cycle, installation, or utilisation category.
Given the context (a DIY forum, hence primarily domestic, and certainly not industrial), I'm not at all surprised by that, but I am rather surprised that you're surprised!
The situation with cable is clear-cut, in domestic installations the same as anywhere else. All electricians hopefully know, and anyone installing cables should know, that the current carrying capacity of a given cable varies appreciably between a fair range of installation methods which are encountered in domestic installations. Furthermore this topic is covered in considerable detail in regulations, guides, books, on-line resources and training courses.
In contrast, neither instructions/standard documentation associated with accessories designed for domestic use nor any of the usual reference documents or (AFAIK) training make any mention of the need to consider any dependence of accessory current ratings on any factors (usage, installation method etc.) other than, perhaps, extremes of ambient temperature. The assumption (yes, I know! - so perhaps I should say 'implication'!!) is therefore that the stated/marked current ratings of accessories remain applicable in even the 'worst case' usage/installation situations likely to be encountered in a domestic (or many commercial) installation.
Do you really disagree with that? Taking the example of a switch, do you really think that there are (domestic) situations (other than, perhaps, unusually extreme ambient temperatures) in which an electrician should consider the possibility that a switch's current-handling capacity may be less than its "rated/marked" value?
Kind Regards, John.
