Hi guys, this is my first post on DIYnot. I'm a total novice so I hope you'll be kind on me!
I have a few questions I hope someone may be able to answer, all concerning a radiator in my attic room.
The radiator has a TRV fitted to it but it seemingly either kicks out full heat, or no heat at all, even when the dial is set at medium. Is this a faulty TRV?
If so I will need to replace it, and use the opportunity to decorate behind the radiator.
I have read tutorials on how to replace the TRV, which looks fairly straightforward, however I am unsure as to how to drain the system, or whether I need to.
We have a combi bolier and I'm pretty sure there are no bleed off valves, however there are two isolating valves on the pipes that leave the boiler.
Any help is much appreciated!
