Check coolant light comes on when starting the engine.
5 Feb 2012
Salisbury
I started the car up yesterday morning, after a few seconds the light came up red and flashing and message saying check coolant in manual. After it warmed up a bit i turned engine off and started it again and light went out. I used the car for a couple of hours with no problems. This morning the light was back first thing. I let it idle a bit then started it up and no light.
Any ideas? The coolant is full.
Faulty sensor
Thanks everyone.
Agreed - they are usually in the expansion tank.
Which vehicle is it?
John :)
B6. I just looked at videos on utube. Theres several showing the sensor in different places. It seems you take a few bits out to get to it, including battery.
Frost overnight! Is the anti freeze strength correct.
Coolant is due for a change so I think it's a must.
Thanks everyone.
A top up of coolant might be enough. with your car a lot of them have coolant for life. Do you know which type of coolant you have?
Joys of modern electronics, I've just discovered that unless my car's tail lamp bulbs are exactly the right type (not just the correct fit/wattage) the 'check tail lamps' warning on my cluster is still showing although the lamps are illuminated.
I say 'modern' though the car's design is 30 years old.
G12 I believe. I was going to get a prestone one from euro car parts. Apparently you can mix it with anything and put it in any car.
