OK - gonna build my own.
Up to 6 each low continuity and high IR positions available - what values should I pick?
Do you want to build two?
Ah, but this isn't about price, or ease - I shall enjoy making it.BAS - get one off Fleabay for the price of a small round of drinks - far easier than making your own - more time to spend down the pub.
Here's a guide to a 'DIY' checkbox from another forum:
http://www.talk.electricianforum.co.uk/showthread.php?t=12[/QUOTE]
The instructions you refer to are similar to a box available on ebay for 20 quid, yet the make your own version costs over a tenner in parts alone![]()
Surely there are better things to do with your free time?![]()
Why do you doubt that?A lot depends on what you are trying to achieve with the check box. If it is simply to provide an indication that an instrument is 'probably' functioning as well as it did when you got it - then a few simple test resistors will be fine. If you expect more (and I doubt that you do) then it can all get much more complicated.
Similar to my initial thoughts, although I was also going to go higher - accurate or not one does see higher values IRL..For insulation resistance I often use:
0.25 M Ohm
0.50 M Ohm
1.00 M Ohm
2.50 M Ohm (because I have a resistor of that value)
10.00 M Ohm
I don't bother going higher because I have serious doubts about achievable accuracy (due to testing method errors) once the readings get much higher than this.
It may work, but it's a bit tacky....My test resistors happen to be high stability 1% types. Note: My check box is actually a few of these with one end twisted together and taped with stick backed plastic - some say I don't take this subject seriously - but what do they know![]()
My tester delivers a few '00 mA at 5-9V, so I was going to use resistors of a few watts..For continuity I use some very accurate (0.05%) non inductively wound, high current resistors (over 1 A). These have various values below 1 ohm. I just happen to have these and I am not suggesting that they are essential. I would probably look for high stability wire wound 1% resistors with as high a current rating as possible within price constraints.
Well I'm certainly not planning on building an adjustable RCD simulator that the posh proprietary boxes have - I was just going to have an actual RCD in there.I don't know what you intend for RCD and Loop Impedance - both are difficult.
RCD checks tend to involve a calibrated test current and a "time measurement" (actually a measurement of output voltage reduction).
Funny or not that's what they do, so as long as I can show that it does the same funny thing each time...Loop impedance testers are a joke- but most test boxes check them by adding resistance (funny for an instrument that is supposed to measure impedance).
I'd been thinking 1 ohm, rated at 200W or so....I do have a 'proper' test box and I think that adds 5 ohms (it is a long time since I bother using it)
