i go to a lot of the WB greenstar range that have pin holed
Was PEDANTIC`s sense check sensitive enoughNot sure if this is the right place to post but wanted to sense check a quote I have had. , thanks for any advice.
True - but it's still easier to imagine the weight of 3 "average" people than a load of kilos, pounds or cwt@ Powell and Ollie
If you want to stick to Imperial, it's normal to switch to hundredweight ( 1 cwt= 112 lbs = 8 stone ) when you get into bigger numbers. Stones for people, cwt for big lumps![]()
There is one manufacturer who makes his own primary heat exchanger in his own factory - and gives a 10 year warranty against perforation due to corrosion.
