Hi all,
I've got an issue with my chimney I'm looking for some advice on. Property is a 90's build which we've recently moved into. Poking about in the loft late Autumn I noticed damp on the rafters/joists around the chimney. The chimney construction is per the below, though there is also a DPM in the chimney brickwork below the felt line (second pic - visible just below the batten).
I've been up several times in the rain now and it is clear (though perhaps not from the picture) that the face of the bricks above the DPM are wet which then pools on the DPM and drips onto the rafters/joists. Bricks below the DPM are bone dry. As you can see it can get pretty wet in heavy rain..
A roofer has taken a look and ultimately made three visits (on the original quote to his credit). First visit he re-fixed the flashing, second time he removed the tiles/inspected the felt/repaired a pin prick in the lead gutter, third time he coated the chimney in water repellent. He says the flaunching, pots/caps and pointing is all OK.
Unfortunately the leak remains and if I engage him again it'll be for more significant work. I'd to go into the next conversations more educated with wider opinions/understanding behind me.
So what is causing this and what's the best approach to resolution? Re-point and re-flaunch to see if that fixes it? Is there something fundamentally wrong with the construction?
Other points worth noting. The house is unique in the area bar a mirror on the other side of the street and that chimney doesn't apparently leak in the same way (albeit elderly owner so perhaps not exploring the depths of his loft regularly). Secondly there was a large dead wasps nest in the loft to the corner of the chimney (do wasps like to burrow in pointing?). Finally, the chimney isn't in use, but I couldn't say for how long for certain beyond about 4 years.
Apologies for the long post, thanks for bearing with me!
