D
Deleted member 174758
Not if you use P5 it won't. If water is left on any timber product (including plywood, softwood, etc) over a number of years, it will rot. The problem isn't just confined to chipboard. Older builds from the 70s and 80s into the 1990s used square edged full sheets and the chipboard available then wasn't moisture resistant. Things have changed somewhat in the last 20 years and all the stuff we lay these days is moisture resistant (P5) spec. BTW I don't do much pure domestic new build - we're mainly on commercial builds where there is probably a greater chance of stuff needing to be reconfigured (i.e. floors coming up) and where traffic/loadings far exceed any domestic environment.Or there will be a water leak and it will turn to mush.
Face it, John, you are really just a chipboard snob
