    Dismiss Notice
Choosing a Ladder
Discussion in 'Roofing and Guttering' started by stevec59, 17 May 2019.
  1. stevec59
    stevec59
    10 Feb 2006
    281
    Thanks Received:
    2
    Essex
    Country:
    I wasn't sure where to post this, I'm after a replacement ladder, Currently I have an Old Beldray Gazelle 5 Step + Platform, missing feet, it wobbles. I have a bungalow and use it a lot for cleaning gutters, I would guess they are 10ft from the floor, I have a gutter cleaning tool for the job, I also clean neighbors bungalow, so it is used a fair bit. The ladder I have at the moment isn't really tall enough, also I'm not sure what is the highest that you can stand on, I'm fairly certain that you shouldn't stand on the Platform? I guess that is there to put things on? What about the top rung \ step? I have measured my top step height to be 44" (1.12m), that is with the ladder open and measuring to the ground.
    I also have the added complication that my driveway slopes away from the bungalow, so when I put the step ladder up it's leaning down the drive, I use it 'Side On' to the gutter as that works best, I did think about putting a plank of wood to lift the side that drops?
    I also have a Flat roof over the extension at the back, I like to check that every year, that seems higher, at the moment I borrow my neighbors extension ladder, that does a great job, but wouldn't want to use it for gutter cleaning, if there was 1 ladder that I could get for both that would be great, maybe a combination ladder?
    Thoughts please,
    Many Thanks.
    Steve
  2. ^woody^
    ^woody^
    3 Sep 2006
    28,866
    Thanks Received:
    3,676
    West Mids
    Country:
    • Thanks Thanks x 1
    • Like Like x 1
  3. Sponsored Links
  4. stevec59
    stevec59
    10 Feb 2006
    281
    Thanks Received:
    2
    Essex
    Country:
    Looks great, I live the securing Brace.
    Steve
  5. blup
    blup
    5 Nov 2007
    1,047
    Thanks Received:
    157
    Country:
    • Thanks Thanks x 1
  6. Sponsored Links
  7. stevec59
    stevec59
    10 Feb 2006
    281
    Thanks Received:
    2
    Essex
    Country:
    Thanks. When I had a look at the video for the 'Youngman Multi-Purpose folding ladder', the hinge things look to be a bit of a Pain!
    The Werner 12 way looks pretty good, I like the platform, if I need to replace the mastic around my windows, that would be very useful. I also need to key an eye on how much they weigh, the werner is 14.2 kg, where as the Youngman is 11.5kg, quite a difference, but there again I guess the Werner includes the weight of the actual Red Platform, so if you don't need to carry that all the time probably not a lot in it & the Werner has 25 tear warranty.
    Steve
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
