if the bits are of moderate quality or above, they should have the steel alloy identification stamped on them. good hand tools are usually CrV (chrome vanadium) alloy, a durable combination of hardness and toughness. Usually bright, shiny and silvery
Impact driver bits wear out fast, so are made of CrMo (Chrome-Molybdenum) alloy, which is harder and stronger. They should also be thicker and heavier. Usually dull dark grey matt.
very cheap tool s may be made of carbon steel, which is rubbish.
Yeah, none of my bits have got any quality ID stamped on them.
I've got the following bits.
Set 1: T10, T15, T25, S4, S5, S6, PH1, PH3
Set 2: T10, T15, T20, T25, T30, S5, S7, PH1
Bosch Set: PH0, PH1, PH2, PZ1, PZ2, S4, T10, T20, HEX4, HEX5
Socket Set: 4mm, 4.5mm, 5mm, 5.5mm, 6mm, 7mm, 8mm, 9mm, 10mm, 11mm, 3/16, 1/4
