Chrome Double Switched RCD Protected Socket
13 Jul 2006
Manchester
Please could someone inform me if a Chrome Double Switched RCD Protected Socket exists, and if so, the cost and where I can get my hands on one?
Thanks in advance.
I have only ever seen RCD protected socket fronts in white plastic and metal clad, never in fancy finishes.
How feasable would it be to use a standard chrome socket front, and fit the RCD futher upstream?
Never seen one, but if you have a modern CU by a good maker, you could use an RCBO and any ordinary socket that you like.
GET do two styles of polished brass RCD sockets, but still no sigh of a chrome one
Why can't you run a RCD fused spur unit to feed a standard 13amp double socket in any finish you like?
The RCD spur unit could be mounted in a fitted cupboard or similar.
