Many incidents have happened because what was "glaringly obvious" to many people was not "glaringly obvious" to everyone,
I've just sort-of conceded/agreed with that. However, these exchanges are, in my opinion, getting a little silly, so let me summarise my personal position:
1...When the earth connection arrives as a core in a cable, and if the accessory has any sort of earth terminal (even if only for a metal faceplate) (i.e. excluding things like plastic light switches), I personally would always take the CPC to that terminal and then run a 'flylead' from that terminal to the backbox.
2...In the rare situation in which an existing CPC was not long enough to reach the light switch, I might take it to the backbox, with a flylead going from there to the accessory - but that's a 'swings and roundabouts' situation since there will inevitably be an extra 'joint' in the CPCs route to the accessory, whether by extending it or at the backbox terminal.
3...Since it corresponds with many people's views of what should be done ('best practice') and since it certainly does not do harm, my advice to anyone else would be as above.
4...However, despite all of the above, I continue to wonder whether anyone has
ever suffered a 'significant electric shock' (i.e. excluding static discharges) by touching a faceplate screw, which suggests to me that the theoretical risk is so low as to not really need consideration. One can, as you have done, invoke the fact that one-can say that it 'never happens' but, as I have attempted to illustrate, application of that approach in general would make life, as we know it, almost impossible.
[in writing the above, I've just realised that the update to the forum software appears to have caused us to loose the options for for bulleted/numbered lists and/or indenting of text; I'll raise that issue elsewhere ]
Kind Regards, John
