- Joined
- 7 Mar 2004
- Messages
- 298
- Reaction score
- 4
- Country
My towel radiator valve is leaking from the centre where it screws in rather than from the pipe or radiator joints. I've seen plenty of articles/videos on how to use a "string" of PTFE to pack a gland on a standard radiator valve but I can't find anything on these now common towel radiator specific valves.
As you can see from the picture, I was able to take the top off and I was even able to un-tighten the small nut at the end. I then added some PTFE and screwed it back in but it doesn't seem to have done anything to improve the situation - it's still weeping (from the centre - you can see the drip) and the amount depends on whether I open the valve fully or not.
Can anyone suggest what the solution is and/or where I can find information on how to fix it? It's either that or I guess I'll have to replace the entire valve which means draining down the system.
