citroen berlingo 1.8 diesel fuel solenoid
15 Mar 2010
Derby
hi can anyone tell me what the solenoid is for on the side of the diesel fuel pump it has 2 wires on it ,I have just bought a berlingo verte x reg and it is disconnected, it starts and stops as normal, thanks ellsie
The fuel solenoid is usually there to stop the engine, by cutting off the fuel to the engine when you turn off the ignition switch and remove the key.
How do you stop your engine, by stalling it?
Wotan
I think the solonoid your are looking at is the cold start advance, the fuel solonoid is under an armoured cover on top of the pump if its a mechanical one.
Peter
On the XUD9 engine the shut off solenoid is on the top of the pump and has one wire...if its a DW8 motor the shut off is deep inside the pump so I think Peter is correct. For the life of me I can't understand why anyone would disconnect the advancer though.
John :)
