Just looking at this as an option, existing walls are rather pants, mortar/rubble built, and very cold (Despite being insulated from the outside)
I want a nice new (breathable!) inside finish, and attempting to straighten out the existing walls without half the render falling off by mistake will be a nightmare.
Rather than dot'n'dab which I hate, I am looking at taking down the existing render and building up a new internal wall in front of the old walls, but the question is this:
In order to span above the windows/doors etc I will require lintels, the lintels only come in 125,150, 250, 300 and 375mm wide.
I won't be able to cut into the existing wall as the windows already have lintels above them.
So how do you get around this, make a temporary shuttering with rebar inside it and cast it in situ out of concrete?
Wouldn't this create a huge cold bridge (Especially since its above windows and doors)?
Alternatively I could take a non-reinforced 150mm beam and cut it in three lengthwise but I doubt this would like the extra 1-2 courses above it resting on there.
Any suggestions are welcome.
