Hi Everyone.
I was given a non worker Stihl Edge trimmer and due of this cold weather, I decided to take it apart during the weekend.
Compression test was 75psi. I then decide to remove the cylinder to see inside the condition and found a nice score starting from the bottom to the below of the inlet port.
As I`m a newbie and self taught I still have no clear how the engine works and if the score below the inlet / outlet port compromise the compression.
I know this may sound a stupid question but can anyone clarify this for me?
This will help me understand if piston and ring would be enough to replace or you need to spend much more on the full engine kit.
