Hi
Apologies if this thread is in the wrong section but I hope it comes under the "central heating" header. I have a plastic domestic fuel tank (for our fuel boiler), 1500L which needs cleaning. The quotes are coming in ridiculously high so I'm considering doing it myself. The tank has 4x 7cm wide holes at the top and unfortunately no drainage from the bottom which makes it a little trickier. The pros have said they will just use power hoses to clean it down, suck all the liquid out and dispose of the liquid safely. Because I don't have a suction device, I was going to move the tank (it's light as it's plastic), put it up on its side and then use a power hose and drain the liquid out. My only cost would therefore be disposing of the liquid which I can do at the local tip for not much cost.
Before I attempt the operation I was wondering if anyone had any thoughts/experience/advice on the process.
NB
NB
