I previously made a post about having to replace a broken boiler but I now have a different question.
I was going to be replacing all but two of my old radiators & seeing as the old boiler has gone kaput, I thought it prudent to do this at the same time as the boiler. The thing is, would the system still benefit from one of the power flushes, or would a quick flush through with clean water suffice, seeing as there are only two existing radiators left, that have only been in the system for under two years.
The guy that is doing the boiler fit for me hasn't got the gear for a powerflush, he usually subbies it out & if can get way with paying another £300 or so, I would like to be able to.
I have already removed the older radiators, ready for the new ones to be fitted once I get them this weekend. The system was filled with inhibitor as well.
I have seen posts referring to x400, would it be a good idea to run this through the new set-up forra few weeks, then drain and refill with clean water + inhibitor ?
Finally, the lad who is going to fit the new boiler for me suggested that this old pump :-
be replaced. He was quite surprised that it was still working as the system is nearly 20 years old & he told me that these pumps were notoriously unreliable. I'm a fan of the "If it ain't broke don't fix it" adage, so is this an unnecessary expense ? If not, what would be a good replacement ? Don't worry about the wiring btw, it's been sorted, thanks to the guys on the Electrics section
Thanks as always.
Thanks as always.
