    Dismiss Notice
Closing fireplace opening
Discussion in 'Building' started by SALL2009, 5 Aug 2010.
  1. SALL2009
    SALL2009
    15 May 2009
    711
    Thanks Received:
    4
    West Midlands
    Country:
    I have removed two old fireplaces from the living rooms and want to close the openings up and wallpaper over. Just wondering, is there anything special I need to do or would simply battening and attaching plaster board is all that’s needed?
  2. theoldun
    theoldun
    18 Apr 2010
    1,244
    Thanks Received:
    326
    Bedfordshire
    Country:
    Stud and plasterboard will do. Tape and feather out joint. Size or seal plasterboard before sticking wall paper. Fit hit and miss air brick just above skirt line to vent flue
    oldun
  3. Sponsored Links
  4. r896neo
    r896neo
    23 Feb 2007
    4,767
    Thanks Received:
    780
    Belfast
    Country:
    also fit a vented cowl top the pots if you haven't already
  5. SALL2009
    SALL2009
    15 May 2009
    711
    Thanks Received:
    4
    West Midlands
    Country:
    I'm assuming, I wouldn't be able to paper over the air brick and it would be visible?
    What size brick should be used?
    And any chance of a link for the item?
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
