- Joined
- 8 Oct 2008
- Messages
- 13
- Reaction score
- 0
- Country
I have an old Potterton Kingfisher floor standing boiler. My hot water is gravity fed and my heating is pumped.
The problem I have is there is a loud "clunk clunk" noise from somewhere (sounds like from a pipe). This noise occurs when the HW only is on, and when it gets to a certain temperature. When the boiler fires down, so the "clunks" get slower until it stops. Now, this is the strange bit, if I turn on the CH, the noise does not occur. Even more strange is the fact that when the HW only is on and I isolate the pump, the noise stops. As soon as I turn the wheel to re-instate the pump (not pumping of course), the noise starts again. Now, when my kitchen was modernised, the pipes from the boiler run behind a stud wall. I did notice before that there was a check valve on the CH flow pipe half way up the wall. My only thought is that this has failed and the heating of the water in the flow pipe is enough to agravate the check valve (loose part inside maybe) and it makes it rattle, but I haven't convinced myself this is the problem. If the valve was faulty, surely upstairs rads would become a bit warm.
So you see, I am totally puzzled! Anyone got any suggestions as the noise is doing my head in!
Many thanks.
Many thanks.
