H
Hot&Cold
Is this the only vertical radiator on your system ? If you have more of the same width then exchange it as the kitchen radiator could be faulty.
What is the make of your vertical rad ?
you have not mentioned the heating system pump,this has to be on the correct speed and of a suitable head for your extended system.
you could check the adjustment of the auto bypass,it could be fully open and not allowing flow to furthest radiators. temporary close off the bypass valve and check if your vertical rad gets any hotter,then reset it to where it was (half way or there abouts).
Your kitchen radiator could be plumbed incorrectly but a few checks to eliminate the basics need consideration,
Good luck,
edit,last time opening a pdf here on this site fecked my laptop,so post photos
Good luck,
