Hello all,
This has to be one of the simplest DIY problems known to man, but I can't find the part I need...
Basically, I have a combi boiler in my kitchen, which drains excess water via a piece of rubber tubing connected to a plastic drainpipe. Unfortunately, the drainage is such that water will often back up the pipe and in to the boiler (this usually happens when we use water more quickly than it can drain - any combination of having a shower/washing up/washing machine/central heating etc will cause water to enter the exhaust pipe). This, of course, means that the boiler fails, and needs drained and reset. It's a fiddle to empty the boiler cupboard and disconnect the tube from the drainage pipe in order to let the water out and reset it - not to mention messy as dirty boiler-water tends to get everywhere.
Life would be a lot easier if I could fit a T-shaped piece of piping with a valve to let off excess water when required. The problem is: I can't find one! I've looked on Screwfix and B&Q websites to no avail. I've attached a basic diagram of what I need, and hopefully somebody will be able to give me a model number, or at least a name, for the part I need - I'd be amazed if they don't exist!
This links to a basic diagram (don't laugh!) of what I plan to do:
https://dl.dropboxusercontent.com/u/87009538/Fitting.jpg
The letters correspond to the definitions below.
A: Excess water from boiler
B: Rubber tubing attached to the boiler. Diameter 2cm, stretched slightly to fit around plastic piping below.
C: Plastic piping attached to drainage system. Diameter 2cm.
D: Runoff valve. Would remain closed during normal operation of boiler - only opened when excess water needs drained.
Any help greatly appreciated!
Cheers,
Eddie
Cheers,
Eddie
