Hello all,
The hot water on my Icon 23T has developed a fault overnight. This morning I turned on the shower as usual to find it was cold, so I went downstairs to investigate the fault further.
Boiler readings were fine and pressure was normal. I tested the boiler by turning the hot water tap on and off to see if the boiler fired correctly. The diaphragm is moving out fully and depressing the microswitch. However, there were two problems:
1. Most of the time, you would hear the microswitch click and the fan come on. Normally, ignition kicks in after 1-2 seconds. Is was taking about 5-10 seconds, but still firing.
2. Some of the time, the switch would click, but nothing would happen (hence the cold shower.)
Initially, I thought it may have been a faulty microswitch, but that doesn't explain why it would be delaying the ignition sequence, since the switch has done it's job by that point. Just to add, pushing the overide button on the thermostat receiver produced no faults with the ignition.
This was just a quick test this morning, but I managed to get hot water after a couple of tries. Any ideas where I should start looking properly?
Thanks in advance!
Thanks in advance!
