Hi All,
I am looking for advice.
I have a Jaguar 23kW Combi Boiler (Plumb Center/Hepworth Heating Division).
It's been in for 5 years and not had any problems.
The problem seems to have co-incided with the warmer weather and not needing the central heating on.
The hot water is problematic but will work fine if the central heating is on.
At the moment I can't get Hot Water from the bathroom unless I go into the Kitchen and turn on the higher capacity hot tap.
Even the Kitchen doesn't always work and it can take a good few goes to get the hot water running.
I just had a safety check done by a corgi plumber and all was ok.
I mentioned that sometimes I have this problem and he said it could be either the heat exchanger clogged up with scale or the diaphram pressure valve, he reckoned both were no more than an hours labour which he would do for £45+vat. He would clean the Exchanger or replace the pressure valve depending on what he thought the problem was.
I am happy to pay that kind of money, but would like some reassurance before I call him in.
