and I bet often overlooked
is that soapy frothy water runs through drains slower than no soapy water.
For what it is worth......
The mains pressure water for my shower is heated by passing through a second coil in another wise standard vented hot water cylinder. Low pressure hot water from the cylinder is used for bath and basins and is fed from a cold water cistern 8 feet above tap level.
I think oldbuffer's ideas are good, but I'd part company with him over sealed system. I would agree with your original preference for open vented.Thanks for your reply! I don't have any experience with system design, layout etc but do have a bit of plumbing installation experience, so the physical part of actually installing the system I think I would be fine with, the planning side I would need to do plenty of research on. I would imagine there are fairly template installations for varying sizes of houses that differ little? I have a blank canvas so can keep the layout fairly simple. Or do you think the planning/layout side of things is completely beyond an amateur? (I would put in plenty of research before embarking on it if that helps?!)
The idea of a vented system appeals to me as I believe I could install everything past the boiler myself so save money and I would then be completely familiar with the system for any repairs in future. Although the idea of a sealed system with unvented cylinder does seem a bit more appealing now I have researched it. Would this kind of system cope with the demands of 2 high power showers and taps around the house provided my mains pressure was good enough? Also if the mains supply is a small bore would having a new supply installed help with this?
Agreed, and there's no risk of it cutting out on low pressure (you often see that mentioned on these forums) and need to top pressure up. There's no vessel with bladder which can fail. And unlike a sealed system it doesn't need a pressure relief valve.My main reason for liking open vented is I can install most of the system myself, maintain it myself and avoid the annual servicing cost of a gs3 qualified plumber.
So what does everyone think of the thermal store idea?
My thinking is they are too complicated with all the essential safety devices that have to be included.
I have mains pressure hot water for the shower and low pressure hot water for all other hot taps. Taps are fed from a conventional (*) vented hot water cylinder with cold water storage tank a metre above it . The shower is fed with mains pressure water, the hot supply being heated by passing it through a second coil in that same hot water cylinder.
(*) Conventional in the way it is heated but bespoke in that it was ordered with a second coil fitted into it.
I am talking about an open vented thermal store?
I thought due to the lack of pressure these had less safety requirements than an unvented cylinder?
