Hi Guys,
I am in the process of letting a contract to replace two Beeston boilers with two Potterton FS 130 Sirius condensing boilers with a indivdual nominal heat input of 135.52Kw in a block of 18 flats consisting of 30 bedrooms.
I understand that under a European Directive for Energy Effiency we are required to fit TRV's in all rooms bar the room with the room thermostat and a motorised valve at the inlet to each flat off the risers.
If you know of this legislation can you please post a link.
