The person involved looked bewildered!!! (I would have been too)
On the two occasions it has happened to me I was!
What's going to be creating an arc? Anyone who tries puling a DNO fuse whilst it's carrying current is clearly asking for trouble and would be well advised to don some serious PPE!What happens when you create an arc with a fixed voltage supply?
When will the bewilderment subside
Kind Regards, John.
Pulling the fuse might go fine 99% of the time. The other 1%, you've just permanently damaged your eyesight and lost half the skin on your hands and arms, and probably face.
These days the highest rating fuses I pull are 100amp and sometimes 125amp on sub-mains. I "almost" always put a current clamp on the tail first to ensure no appreciable current. But I am the first to agree with your comment that most of the time its fine but just that 1 in 100 time it could lead to serious regret.
Fair enough. I suppose that uncertainty does create a risk.How are you ensuring there's no current flowing?
Still up to several kA PFC though, and you can't always access the tails for a clamp! I've seen quite a few installs with the meter butted up to the cutout with no access to the supply side tails at all.
There are no more reasons why the connections in an isolator should be flaky than the ones in henley blocks, switchfuses or CU incomers.A final point in this post, there seem to be agreement that connections are a weak point in an installation, yet here we are discussing adding a further 4 connections at the point of highest load of an installation!
