Hi, I was just wondering if anyone out there could help me with a bit of a complicated electrical problem?
At the moment I've got a 30amp radial circuit (4.0mm cable) in a garage/workshop type building, which goes about 10m from the consumer unit to the first single socket, then carries on for about another 12m to a junction box in another room, which then splits up to go to 2 sockets.
What I'm wanting to do is insert a spur at the first socket. I've got a ton of 2.5mm flex cable hanging around (but no 4.0mm mains cable) so I want to utilize this. Would I be ok to run a spur from the first socket on the circuit to a 20amp Fused Connection Unit (using 4.0mm mains cable) and from the FCU run the rest of the spur using 2.5mm flex cable? I just don't know if you can go from 4mm to 2.5mm cable (but figured that maybe an FCU would 'sort this out'?)
What I'm wanting to do on the spur is run 8 double sockets, about 2-3m apart each. Of course, Im not planning on plugging in 16 different appliances, it's just for the convenience because I'm building a studio, and I need to have a load of sockets around the top beams for plugging in 4-5 500w lights at any one time, and because the lights will be high up I can't just plug them into extensions.
Any help would be greatly appreciated, because like most people I don't want to fry myself or cause a big ugly fire.
Thanks! Lee.
Thanks! Lee.
