    Dismiss Notice
Composite door, weatherstrip and frame rotting
Discussion in 'Windows and Doors' started by btb23, 5 Oct 2015.
  1. btb23
    btb23
    9 Jul 2009
    79
    Thanks Received:
    3
    Leicestershire
    Country:
    The composite back door on our 1997 built house is rotting at the bottom. The weather strip rotted first and was replaced about 5 years ago. The door frame is also rotting at the bottom as can be see in the photos.
    Can you tell from the photos what kind of wood rot this is?
    What is the best plan to rescue the door and frame and stop the rot before it becomes too bad?
    Thank you for any help and advice.
    IMG_20151005_094043196_HDR.jpg IMG_20151005_094052715.jpg IMG_20151005_094108924.jpg IMG_20151005_094120663.jpg
  2. Sponsored Links
  3. crank39
    crank39
    1 Dec 2009
    4,943
    Thanks Received:
    861
    South Yorkshire
    Country:
    Barbados
    Doesn't look like a composite door to me, any chance of a full view picture? Composites tend to have Ali weather strips so to have a timber one planted onto it is very odd!
    Also it clearly opens in so why is there a gap down the lock side, where's the clapping strip gone?
    • Thanks Thanks x 1
  4. btb23
    btb23
    9 Jul 2009
    79
    Thanks Received:
    3
    Leicestershire
    Country:
    Thanks for your reply. The original weatherstrip was wood.
    Here are some more photos, do they help understand the type of door?
    IMG_20151005_103131.jpg IMG_20151005_103139.jpg IMG_20151005_103227a.jpg IMG_20151005_103054.jpg
  5. Gazman16
    Gazman16
    27 Apr 2011
    2,470
    Thanks Received:
    413
    Somerset
    Country:
    Composite doors are either fiberglass or steel so they dont rot, Thats just a wooden door.
    To be honest that looks like its already too far gone to me and needs replacing or will do soon.
    Might be worth posting some links to this thread on the woodwork section and maybe the painting/decorating section.
    • Thanks Thanks x 1
  6. btb23
    btb23
    9 Jul 2009
    79
    Thanks Received:
    3
    Leicestershire
    Country:
    Thanks for the clarification. I didn't know for sure what a composite door was, this one looked different to older wooden doors I've had before and thought it might be one. As you say its all wood.
    I'm going to repair it as I can't afford a new door and it's only the bottom that's affected. It seems to be the outer finish thats rotten, looks like a skin of hardboard over another kind of wood. The wood under the hardboard is quite solid, though obviously needs treating. I'll cut it off in a straight line above the rotten section, treat it the whole of the bottom area with "Everbuild Triple Action Wood Treatment" and put a new piece of hardboard on.
    Similarly repair the bottom of the frame. And hope it lasts!
    Edited to say the outer skin is probably 3mm plywood or MDF and not hardboard, so that's what I'll use.
  7. Burnerman
    Burnerman
    7 Feb 2008
    23,143
    Thanks Received:
    4,500
    Northumberland
    Country:
    I really think it's done it's bit, but definitely don't use MDF whatever you do!
    John :)
    • Thanks Thanks x 1
  8. btb23
    btb23
    9 Jul 2009
    79
    Thanks Received:
    3
    Leicestershire
    Country:
    What would be best to use, hardboard or ply? Under the outer skin it's not rotten, it's probably starting but the wood isn't soft. Seems a good plan to repair the door.
  9. Burnerman
    Burnerman
    7 Feb 2008
    23,143
    Thanks Received:
    4,500
    Northumberland
    Country:
    Well plywood if you must but expect to do the job again in no time......really not trying to sound like a smart arse here but door repairs are rarely successful......weather gets in come what may.
    Can you get the door off and on to a bench?
    John :)
  10. Sponsored Links
  11. crank39
    crank39
    1 Dec 2009
    4,943
    Thanks Received:
    861
    South Yorkshire
    Country:
    Barbados
    I'm no wood expert but they make green MDF that's meant to be waterproof, whether it is or will work is another matter otherwise its a job for marine ply
    • Thanks Thanks x 1
  12. Burnerman
    Burnerman
    7 Feb 2008
    23,143
    Thanks Received:
    4,500
    Northumberland
    Country:
    I think I'd cut back to just under that moulding edge, and then fill in with exterior grade ply to whatever thickness is needed......maybe even use pressure treated timber.
    Fill any gaps with epoxy filler and then paint - its about all that can be done.
    John :)
  13. btb23
    btb23
    9 Jul 2009
    79
    Thanks Received:
    3
    Leicestershire
    Country:
    OK, although that isn't what I wanted to hear I definitely appreciate your advice. The cost of a new door being out of the question I've got no choice but to either leave it and save up, or spent perhaps £30 and give it a go. It's only that outer skin thats rotted, the inner wood and sides are unaffected.
    It wouldn't be easy for me to take the door off, so I'd have to do it in situ.
  14. Burnerman
    Burnerman
    7 Feb 2008
    23,143
    Thanks Received:
    4,500
    Northumberland
    Country:
    OK, give it a bash and we hope it goes well!
    This isn't a rented property, is it?
    John :)
  15. Gazman16
    Gazman16
    27 Apr 2011
    2,470
    Thanks Received:
    413
    Somerset
    Country:
    You have to admire the standard and quality of modern British newbuilds, MDF external doors :eek:
    It will be cardboard next to cut costs. Oh well it keeps us PVC guys busy :D
    • Like Like x 1
  16. btb23
    btb23
    9 Jul 2009
    79
    Thanks Received:
    3
    Leicestershire
    Country:
    Yes, that sounds the best plan. I'll do it this way, treating the wood first. I'll post up the results, and then hope for the best.
    Thank you all for your help, I now know what to do!
  17. btb23
    btb23
    9 Jul 2009
    79
    Thanks Received:
    3
    Leicestershire
    Country:
    Thank you, not rented.
Loading...
Share This Page
